Re: Wiring a H rotary light switch - has negative gnd system
Posted by mkirsch on July 30, 2014 at 12:36:50 from (72.45.143.81):
In Reply to: Wiring a H rotary light switch - has negative gnd system posted by Alan in VA on July 30, 2014 at 12:22:34:
Wiring is exactly the same, whether 6V, 8V, 12V, positive or negative ground.
The only connections you do NOT need are the ones running to the cutout, if that's the type of system you had before.
Your switch will only have connections for hot-in and lights-out.
