Re: double bottom plow
Posted by BMD on July 31, 2014 at 08:22:01 from (107.4.214.137):
In Reply to: double bottom plow posted by Paul Bertrand on July 31, 2014 at 07:06:41:
A lot of 140s were originally sold with a pair of 14 inch bottoms. Sometimes, this was to much plow depending on soil type. With weights all around and maybe fluid loaded rears tires you would probably be OK in lighter soils (sandy). Used front and rear weights are readily available. I see you have rear weights.
In areas with heavier soils(clay)a better match would usually be a single 16 bottom.
If you go with the plow you are considering you probably find the front end to be very light without adding front wheel weights.
