Re: c113 c123 valves
Posted by mkirsch on August 01, 2014 at 10:29:02 from (72.45.143.81):
In Reply to: c113 c123 valves posted by calcubman on August 01, 2014 at 06:23:21:
You must get the correct valves. Ideally, if you can get a valve out and measure it, then order the correct set.
