Re: Farmall B chasing
Posted by soundguy on August 01, 2014 at 18:38:30 from (207.30.46.70):
In Reply to: Farmall B chasing posted by Farmallstrong on August 01, 2014 at 18:26:33:
run the carb butterfly manually and see if the engine keeps up or stalls out under load.
many times hunting can be a lean condition ( fuel blockage or otherwise ).
can also be bad gov or one with comp springs set with preload or slack depending ont he gov linkage setup and type.
