Re: Farmall B chasing
Posted by Lmack on August 01, 2014 at 19:03:07 from (24.131.50.165):
In Reply to: Farmall B chasing posted by Farmallstrong on August 01, 2014 at 18:26:33:
If it has been sitting up for a while, drain the bowl on the carb, blow out the fuel line, and clean the bowl under the tank even if it looks clean. Be sure a good steady stream of gasoline flows to the carb (reverse the fuel line and turn the fuel valve on). If it has been a several months since it ran it might take more than one time through this process to get it to consistently run correctly. Do this before you start messing with the carburetor settings. If it ran well and just started giving trouble I would suspect water in the gasoline which also gives trouble under load. Make sure the fuel line has no loops and has a continuous down slope from the tank to the carburetor.
