Re: F-20 Belt Pulley Nut
Posted by SweetFeet on August 02, 2014 at 05:45:24 from (70.35.103.74):
In Reply to: F-20 Belt Pulley Nut posted by Dan Oehmke on August 01, 2014 at 19:28:29:
Ditto on the 1 inch fine-thread castlenut.
If you want an original one, sometimes they are available on flea-bay.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
