Re: 560D Injector pump question
Posted by pete 23 on August 02, 2014 at 09:08:27 from (74.33.72.212):
In Reply to: Re: 560D Injector pump question posted by jkjkiefer on August 02, 2014 at 07:32:17:
Pictures tell the story. No advance and it will not work satisfactory on a 560. Also, if you do find another pump, make sure it has a load advance and not a speed advance. There is a lot of difference in performance of that engine between the two advances. Load advance will have an adjustable governor guide screw and speed advance will have adjustable screw on the end cap of the advance piston. Like previously stated, two different styles of load advance. One with separate bolt on housing on bottom of pump and the other(latest and best) is integral housing cast with pump .
