Re: Engine Balancer Assembly
Posted by Bernard le mecano on August 02, 2014 at 10:10:53 from (75.152.45.48):
In Reply to: Re: Engine Balancer Assembly posted by mkirsch on July 29, 2014 at 04:55:40:
Hi, don't run without the balancer in place, You don't have oil pressure on the crankshaft, if you remove the balancer. For $425, if the bushings are tight, it's a deal. It have timing marks on balancer and crank gears, make sure the timing is ok when you put in place. Bernard in Quebec Canada
