Re: 560D Injector pump question
Posted by thepumpguysc on August 02, 2014 at 12:15:14 from (67.238.248.242):
In Reply to: Re: 560D Injector pump question posted by jkjkiefer on August 02, 2014 at 07:32:17:
We need to have the complete DBGFC # to compare internal components.
Just because your old pump doesn"t pump doesn"t mean you need a new one.. IF indeed your head and rotor is seized it would have snapped the drive shaft. IF the head is worn out and you already have the "new pump" the internals can be swapped into the old housing if compatible, but we need the #"s off the old pump.
