Re: Blowing head gaskets.
Posted by robert major on August 02, 2014 at 17:31:11 from (216.81.21.228):
In Reply to: Blowing head gaskets. posted by Mr. Farmall A on August 01, 2014 at 10:34:47:
Hi
one thing I have come across with many make
tractors blowing gaskets after new ones are
fitted, Is that sometimes a guy gets a load of
crap like carbon/rust drops down the blind hole in the
block when taking it apart. Then the bolt
can bottom on this. when this happens the torque
wrench clicks off. but the heads not down tight on
one or more bolts. if it"s had more than one
gasket in it"s life with nobody cleaning the holes
out, you could have 1/4 or more junk compressed in
the bottom of the holes.
The other thing I just found on a Deere 8430 motor
was the last guy that did the head before it came
here, after running 2 hours and blowing again!.
Was that he way over oiled the bolts, and the oil
ran down the holes causing the studs to hydraulic
lock, in the blind holes in the block. when i un did the head
it was slack, I know it was torqued correct as
factory trained tech made a big thing out of doing
it correctly/ and updates, when the customer fitted gasket blew
after 2 hours as well.
When I got the bolts out the holes were nearly
full of fresh motor oil, cooling fluid can do the same if any gets in the holes on dissassembley and is not cleaned out.
Might not be your problems but worth a mention from what I have seen personally on these jobs.
Regards Robert
This post was edited by Robert Major at 18:10:07 08/02/14.
