Re: 706 Farmall C 263 Engine
Posted by CDN 400 on August 02, 2014 at 20:20:44 from (67.58.198.88):
In Reply to: 706 Farmall C 263 Engine posted by Alan OFLynn on August 02, 2014 at 19:39:50:
If it has been sitting outside for that long you had better change the hydraulic oil and filter before you try starting it.You will find alot of water in the bottom of it and if you don't stir it up alot it will come out crysal clear as soon as you crack the plugs.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
