Re: Loader for a farmall A
Posted by gene bender on August 03, 2014 at 05:29:53 from (67.55.226.121):
In Reply to: Loader for a farmall A posted by 21tank on August 02, 2014 at 19:11:37:
They didnt make a loader for a 44A because it doesent have a hy system. But you could find a loader for a SA then run a hy pump off the belt pulley. The Char-Lynn Power Pac unit would work just fine as it has the pump,res and single and 2 way controls all in one unit. 10 GPM AND 1000LBS pressure would do anything you could need for hy.It can be ran off the pto as 750rpm is the recomended speed for the unit. I just mounted one on a B and used the I-H loader built for the C,SCs works fine.
