Re: Sockets for Square Nuts
Posted by RTR on August 03, 2014 at 08:53:03 from (66.87.152.121):
In Reply to: Sockets for Square Nuts posted by F-Dean on August 03, 2014 at 06:56:41:
F-Dean said: (quoted from post at 18:56:41 08/03/14) They are called "8-Point" sockets and are the exact size - a 9/16" 8-point socket fits a 9/16" square nut/bolt exactly.
Thank you for all the responses guys. This one has been most helpful. Yeah I definitely need 8 point sockets since they fit the square nuts and bolts perfectly. I didn't realize that if you had a 3/4 square nut or bolt that the 3/4 8 point fit it. For some reason I thought the sizes were different since it were 8 point. I'm looking for 5/8 inch and above, all the way to 1 1/2 inch or so. Most of these bolts/nuts are on cultivator sets that need tightening or other implements where I want to try and save the bolt and nut
This post was edited by RTR at 08:55:56 08/03/14.
