Re: C113 head studs
Posted by Red Dave on August 03, 2014 at 09:44:38 from (174.59.201.239):
In Reply to: C113 head studs posted by Mr. Farmall A on August 03, 2014 at 08:47:34:
I'm not sure I understand how new Head Studs would correct your problem. Unless they are visibly damaged, or somebody along the way replaced them with something unsuitable, I would tend to look elsewhere for the problem.
Are you using sealer on the new gaskets, torquing to 80 ft/lbs and re-torquing after the engine is run a bit and warmed up?
Is the deck of the block flat?
