Re: Blowing head gaskets.
Posted by farmallpuller2014 on August 03, 2014 at 23:58:02 from (69.35.216.123):
In Reply to: Blowing head gaskets. posted by Mr. Farmall A on August 01, 2014 at 10:34:47:
I would take a flat edge and set on top of block and check for gaps with a feeler gauge,a gasket can still seal right if gap is 8-10 thousands,Also make sure to put the gasket on with right side up,the flat side down on block side and the raised edge around the cylinders are up to the head.The gasket sealant can't hurt anything as long as you get it tightened down before it completely sets up.
