Re: C113 head studs
Posted by Mr. Farmall A on August 03, 2014 at 23:59:21 from (68.32.185.8):
In Reply to: C113 head studs posted by teddy52food on August 03, 2014 at 19:45:32:
Is it possible that coolant could leak up through the threads where the studs screw into the block and cause gasket failure or otherwise leak into the cylinders?
I know with some motors the head bolt/stud hoes go into the water jackets and require thread sealant.
Other wise, if it is a wraped block then I am looking at a full engine rebuild?
This post was edited by Mr. Farmall A at 00:37:05 08/04/14 4 times.
