Re: Delco-Remy Voltage Regulator Adjusting/Testing
Posted by gene bender on August 04, 2014 at 07:32:37 from (67.55.226.121):
In Reply to: Delco-Remy Voltage Regulator Adjusting/Testing posted by Jeff Pfeiffer on August 04, 2014 at 06:24:31:
With the engine running ground the field to see if the points close. You can adjust points like other post says. Also make sure the points are clean. Measure the volts coming off the gen when engine is running and points on the cut-out are closed. I have several cut-outs on the Cubs,As and Bs that i have. Also use a meter and put one lead on the Gnd at the battery then go to the knob on the lite sw then to gen then to the cut-out as they all need to have a chassis grnd to operate. Trouble can sometimes be at the lite sw where it fastens to the post thats why checking all parts in the system need to be checkd for chassis ground.
