Posted by Mr. Farmall A on August 04, 2014 at 08:37:47 from (68.32.185.8):
In Reply to: C113 head studs posted by mkirsch on August 04, 2014 at 04:54:55:
I hope it is not that then.
The other thing I am thinking, can coolant seep through the threads of the head studs? I know with Chevy V8s that if you do not use sealant on the head bolt threads, then coolant will seep through the theads and ruin the head gasket seal. Do the head studs on C113 motors also screw into the water jacket and require sealant like SBCs? Could it be the thread sealant has gone bad allowing coolant seepage to mess up the head gaskets.
This post was edited by Mr. Farmall A at 08:38:37 08/04/14.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
