Re: leaky hydraulic auxiliary valve
Posted by JohnAndrew on August 04, 2014 at 09:49:17 from (12.173.204.43):
In Reply to: leaky hydraulic auxiliary valve posted by JohnAndrew on July 24, 2014 at 09:34:34:
Well I think I found the problem. A mechanic directed me to look at the three bolts that hold the plate on. One bolt I could see the treads stretched out, so is install three grade8 bolt and so far so good. I will hook up the three point blade on it tonight to work the system.
One other thing I noticed is when I move the control lever up all the way to raise the arms. When the arms reach the top the travel the system continues ‘ strain’, motor rpms drop. So I lower the arms slight to get them off the top position.
Is there some type of valve that release once the arms reach the top?
Where is it at?
