Re: 574 I-H ....lift the hydraulic unit off rear end housing
Posted by Bernard le mecano on August 04, 2014 at 15:47:24 from (75.152.45.48):
In Reply to: 574 I-H ....lift the hydraulic unit off rear end housing posted by Big Als acres on August 04, 2014 at 11:54:56:
Hi, you can remove the fenders and the sheet under the seat assembly. Remove all the dirt before loosing all the bolts that secure the unit in place. Remove the hydrolic pipe that run over the unit. You have to change the gasket and the 3 O rings under the unit. Check the Orings when you put the unit in place and you have to bleed the brake. Bernard in Quebec Canada
