I pull a Super C in the farm stock class. With the fast hitch, 1/2 a tank of gas, 2 45# front wheel weights on the front and me at 230# it weights right at 3400. I add 4 rear wheel weights at 145# each and pull in the 4000# bracket. It depends on what scale I am on, but I can always take one of the front weights off if I have to. Also I don"t have filled rear tires so I don"t know what that would weight.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
