Re: Delco-Remy Voltage Regulator Adjusting/Testing
Posted by gene bender on August 04, 2014 at 16:11:43 from (67.55.226.121):
In Reply to: Delco-Remy Voltage Regulator Adjusting/Testing posted by Jeff Pfeiffer on August 04, 2014 at 06:24:31:
By the way your generator has an adjustable third brush for final out-put if you are using a mag you only need a couple amps on regular charge if you have a dist you want it to show around 5 amps.
