Re: So close with my H
Posted by jim warehime on August 04, 2014 at 19:18:20 from (174.236.202.19):
In Reply to: Re: So close with my H posted by JakeBrake on August 04, 2014 at 18:16:31:
Yes depending on the type of manifold and where it is burned out it be causing it to run to lean or causing it to suck exhaust back in.
