You should be able to hear the fuel pump running, making a clinking sound. When mine stops running the engine will not run unless the fuel tank is over 3/4 full.
The other thing that may cause the problem is the carburetor shut off solenoid. you should hear it click on and off with the key switch.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
