Posted by peter123 on August 05, 2014 at 04:03:37 from (195.228.173.89):
574 hydraulic oil level I have just changed the hydraulic filter on my 574 and there is no oil flowing into the filter housing.
I am assuming that the filter flows from outside to in and that the filter is on the suction side of the pump not the pressure side.
The oil level is just above the full mark on the dipstick
On the filter mounting on the MCV there are 2 holes, one in the centre and one at the top that would be outside the filter element, when I checked the oil level against these holes the oil is just about to the bottom of the centre hole so no oil could (would) freely flow into the filter housing.
If my assumption of the outside to in flow is correct then the pump would need to suck the air out of the filter housing until oil was pulled in through the top (outside the filter) hole. Is this what is supposed to happen? Or should the oil level be above the top hole in the MCV to allow a flow into the filter housing?
Otherwise how does the filter and its cover get filled with oil after a filter change?
Is the oil level at approximately to the centre of the MCV at the correct level? Or could the wrong dip stick be on the tractor?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
