Mine is mounted vertically just as was said. Same switch used on other letter series. Pull it up to start and run, push it down to shut off (mine is coil/dist ignition). I'm too lazy to go out and look but if I remember right it is on the low idle side of the throttle quadrant up against the steering support pole. When you pull it up you can see the knob over the side of the throttle quadrant teeth.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
