All Super A tractors (built 1947-1954) had hydraulics. Farmall A tractors DID NOT have hydraulics (built 1939-1947). HOWEVER, Some of the VERY LATE Farmall "A" tractors in 1947 had a place for the hydraulic pump on the engine.
The casting code for the rear end you supplied .....not sure about that.
If you got the serial number off the rear of the tractor under the seat then it is possible it has been changed out at some time with a Super A rear end. What is the bolt pattern spacing on the rear final drives? That will tell if from an "A" or not. Also check cast codes on transmission case (probable cause for replacing rear end).
If you are talking about your engine block being blank on the flat spot near #1 spark plug (no serial number), then that is very possible the engine is from a Power Unit.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
