Re: farmall a on off switch question
Posted by Brian Schmidt on August 05, 2014 at 20:30:07 from (69.66.237.150):
In Reply to: Re: farmall a on off switch question posted by Brown Dirt Cowboy on August 05, 2014 at 11:14:17:
My '40 B has the cable. Choke looking cable mounted on the steering post mounted to the mag on the other end. I never use it though. It is a crank start tractor with no battery or electric. So I just shut the fuel off and let her run out of gas. Also note, I never have carb trouble either. No gas in it to go stale or take on water and corrode things.
