Re: farmall a on off switch question
Posted by athol carr on August 05, 2014 at 21:58:57 from (122.57.233.64):
In Reply to: farmall a on off switch question posted by nick from md on August 04, 2014 at 23:48:18:
I think the very first Farmall A tractors had a finger push tab on the side of the magneto. You had to dismount to press the tab. This was then replaced by the Bowden cable operated tab on the magneto and then by the switch to short the magneto
