Well, first off put those two long bolts back in, finger tight then back em off a few turns, they will help you guide it off. There is no hidden bolt on an M. Put a little tension on your hoist and tap on the long bolts. You might have to jiggle the hoist up and down a little. Keep hitting the bolts while you jiggle, once it loosens up a bit pry your way around the bell housing remembering to loosen the bolts as you go. Good luck and be careful
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
