Re: Zachary Holt Farmall H bull pinion bearing cage o-rings
Posted by transtar61 on August 06, 2014 at 19:59:03 from (75.133.150.214):
In Reply to: Re: Zachary Holt Farmall H bull pinion bearing cage o-rings posted by Zachary Hoyt on August 06, 2014 at 18:30:53:
Thanks ,Scott
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
