Re: SuperC 6-12 volt conversion
Posted by old on August 07, 2014 at 10:39:42 from (209.86.226.19):
In Reply to: SuperC 6-12 volt conversion posted by Zwepper34 on August 07, 2014 at 10:31:44:
Trouble shoot then parts NEVER the other way around. Your problem could be as simple as a loose wire or the point slipped etc. Simple test no meter needed is take the ignition side wire off the coil. Turn on ignition then touch that wire back to the coil make sure the points are closed. If you get a spark you have either no problem of a short. Next open the points and try that again. If you have a spark with the points open you have a short in the distributor
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
