Re: C113/123 oil pump cover needed.
Posted by JRSutton on August 07, 2014 at 18:00:03 from (71.174.108.252):
In Reply to: Re: C113/123 oil pump cover needed. posted by XFARMA on August 07, 2014 at 17:22:18:
yeah - I wish I knew the correct thickness, but
they're very thin material. Like newspaper.
And the thicnkess is critical. You basically set
the the pressure by the thickness of the gaske.
Most likely in your case, the thinner the better.
Cork would be way out, it couldn't possibly be cut
thin enough and still hold together.
Xfarma could be right with the 002-005 number, I
just don't know. I do know newspaper's closer to
the .002 number, and that feels about right for
those gaskets so... if all else fails, when
you're done reading the comics, make a gasket out
of that.
