Re: C113/123 oil pump cover needed.
Posted by gene bender on August 07, 2014 at 18:12:42 from (67.55.226.121):
In Reply to: Re: C113/123 oil pump cover needed. posted by PretendFarmer on August 07, 2014 at 15:40:01:
Thick gasket is part of your problem as the gasket is paper thin and using a thick gasket wakes too much clearence for the pump to build pressure and no cement is used. Thin brown paper could be used for a gasket as the only place to get a new one would be from I-H as one from NAPA would be in an overhaul kit cause they probably dont have just the gasket for sale. Do like other post says sand and sand.
