toe-in - 300 U front axle
Posted by 300dave on August 08, 2014 at 07:16:59 from (50.48.60.43):
I have a 300U with a front loader. No Power steering. It steers VERY hard. All four tie rod ends are shot. One tire is standard 3 rib, the other some old snow tire from truck. I have good drag links with ties rod ends to install. My question is: The I&T book says there are marks on all the parts to line up before installing drag links- WHERE? I cannot find them.
Anybody no where they are?
thanks in advance
PS- When I lift the front end and check for play:hands at 9:00 and 3:00 or 12:00 and 6:00, I can't feel any big issues, maybe a little loose in the bearings. In use, sometimes one tire will get knocked way off alignment, like pointing off at the next town. Is this maybe the bushings?
Are these bushings still available?
thanks again
