Final potos and info for C-153 in Super C
Posted by Rex Simpkins on August 08, 2014 at 18:51:54 from (69.251.237.110):
third party image
third party image
third party image
third party image
third party image
Here are the last photos of it almost complete.
Used the following parts for archives
Rear Fuel Tank support from Famall "A"---49601D
140 Radiator---369400R94
140 Radiator brace--369513R1
140 Lower Radiator Elbow 369396R1
140 Upper radiator outlet--367679R1
140 Upper Radiator Hose 369397R1
140 Lower Water Pump Hose 387721R1
140 Lower Radiator Hose-20075DB
Had to use original fan off of power unit but had to remove 1 1/4" off the ends of each blade
