Farmall MD injection pump/primary pump seals
Posted by jim warehime on August 08, 2014 at 19:21:33 from (174.252.112.100):
The seals between the primary and injection pump are leaking causing the pump to flood with fuel. The primary uses a packing with compression nut and spring to seal around shaft that drives the primary, some used packing others use a oil seal. What could I use to replace the packing and either stop or slow the leak? Would graphite packing, felt, leather orings ect work. Don't really want to send it to centeral injection if I can fix it myself. Thanks.
