Re: toe-in - 300 U front axle
Posted by 300dave on August 09, 2014 at 04:35:05 from (50.48.60.43):
In Reply to: Re: toe-in - 300 U front axle posted by Mark Robke on August 08, 2014 at 19:52:37:
index marks- yes- a prick punch on the shafts and line on the steering arms (both on box and knuckle)
; and I guess on "U" models only. I found them after several cleanings. Mostly they line up, but not really precise like timing gears. One is out but I don't think I would make it better by pulling and re-positioning one tooth. I think I will concentrate on the spindles and tie rods ends.
I did not mention that the steering box had been changed at some time as it is a different color.
Both tie rods are bent and had re-bar welded on to fix.
Front rims also don't match, i.e. one has about 1 inch off set and the other 3 inch.
thanks again I'll keep you posted
