Re: 560 d valve adjustment
Posted by Tractordan on August 09, 2014 at 12:44:13 from (50.137.83.148):
In Reply to: 560 d valve adjustment posted by Brad Vaughn on August 09, 2014 at 11:48:16:
I just did mine this morning I just started at front and bumped engine over until one rocker on first cylinder was down adjusted other valve bumped it over until other was down adjust other and just worked my way down the line
I needed valve cover gasket myself figured while off check valves had been putting it off not wanting to remover fuel tank but figured out you can just remove intake tube from manifold an fits tight but it will allow you to get valve cover out through
Good luck dan
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
