Re: 560 d valve adjustment
Posted by Owen Aaland on August 09, 2014 at 17:22:21 from (216.47.34.49):
In Reply to: 560 d valve adjustment posted by Brad Vaughn on August 09, 2014 at 11:48:16:
Timing marks are on the front crank pulley with a pin sticking out of the front cover. When coming up on #1 both valves will be moving on #6.
When ever you see both valves moving at the same time, one closing and the other opening, on any cylinder, the cylinder just opposite it in the firing order will be coming up in the firing position. 1 & 6, 2 & 5, 3 & 4.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
