If you don't have a compression leak, sounds like a thermostat or radiator flow problem. Also might just be the radiator cap needs to be replaced. Does the motor get hot under a heavy load? I have had in the past two D282 motors in a 560 and a 706 both with turbo's. I ran 160 deg thermostats in them. Both were bad on head gaskets blowing if you turned the injector pump up.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
