Re: Glue for a belt
Posted by rustred on August 10, 2014 at 08:42:51 from (74.214.152.80):
In Reply to: Glue for a belt posted by Dave Meisner on August 10, 2014 at 07:33:51:
only way to fix that is with a new belt. the flat belts are fixed with belt lacing. just a thought but maybe could use some leather and drill couple holes on each side of slice and use the brass rivets to rivet the leather on the bad side. thing is then you will not have it fitting the pulleys properly. na don"t think it will work have to run it till it breaks.
