Re: Another successful farmall h 12 volt conversion (w/pics)
Posted by rankrank1 on August 10, 2014 at 19:29:49 from (166.137.101.164):
In Reply to: Another successful farmall h 12 volt conversion (w/pics) posted by mkirsch on August 10, 2014 at 11:42:52:
merlynr,
Is that a wood shim I see under the nosepiece sheetmetal in your pic? Did you have to shim everything out in order to create enough room for the large bodied Delco alternator?
