Re: How many wheel are to many?
Posted by rustcollector on August 11, 2014 at 13:55:31 from (72.104.28.61):
In Reply to: How many wheel are to many? posted by kennell on August 11, 2014 at 10:53:38:
Kent,
Question first might be whether or not liquid ballast is in the tire and tire size and to some extent tread and sidewall condition? In a "liquid" mud/water situation, miring and cutting down will be worsened with additional weight. When the bottom falls out, there is that much more dead weight to drag out. Any number of implements and mounted equipment will out weigh the four weights on each wheel; i.e. planters, corn pickers, cotton pickers, etc.
