Re: Stage 2 h or m hydraulics
Posted by D Slater on August 11, 2014 at 19:00:24 from (184.14.180.79):
In Reply to: Stage 2 h or m hydraulics posted by Ron McQuigg on August 11, 2014 at 18:17:43:
Same size but SH has suction and pressure openings facing the front. Does have a pressure opening on the right side that's plugged. SM has openings on the right side and the operating lever will extend to the right more than a SH. On a SH also the left two mounting holes are slotted.
Few other differences but nothing to keep one from working since you need to make up mounting and are probably going to use plain hydraulic hose to pump.
