Re: 15/30 Question
Posted by L.C.Gray on August 11, 2014 at 19:08:24 from (76.0.111.56):
In Reply to: 15/30 Question posted by Knuckleskinner on August 10, 2014 at 19:07:34:
I know someone who has a 22-36 that he fitted an electric start to. The starter is down in the cast iron chassis tub out of sight. I recall he said he used a 12v Hitachi gear reduction starter and I think he said the ring gear was made from a Honda flex plate. It did require him to cut a chunk out of the tub and he formed a sheet metal cover to disguise it. It was well done and the only tip off at first glance was the battery box and cables.
