Re: How many wheel are to many?
Posted by redforlife on August 11, 2014 at 20:40:45 from (68.234.121.124):
In Reply to: How many wheel are to many? posted by kennell on August 11, 2014 at 10:53:38:
If you are on greasy ground, weight will help you to a certain extent. If you are on mud and sinking in the soft ground is what is happening, its not going to help much if any at all. A tricicle front end will hurt you worse than anything if sinking is the problem. Best thing to do in that case, is only operate when dry. However, if you bolt your front rims on in the widest position will help you, but only to a certain extent and the margin of being better is only minimal. For what it is worth, I would take the front wheel weights off.
