Re: Farmall only runs with choke closed
Posted by JRSutton on August 12, 2014 at 06:39:44 from (71.174.108.252):
In Reply to: Re: Farmall only runs with choke closed posted by R Weld on August 11, 2014 at 18:31:51:
don't fear the carb!
Take this opportunity to dig into it.
Your tractor's dead anyways, you're not going to make it any worse. So it's a perfect opportunity to learn.
Carbs don't get all that much more basic than the M's.
There's very little in there to worry about.
Learn now and the knowledge will pay off more than you can imagine (the next 10 times you have trouble).
Once you do it, you'll be able to field strip it, clean it, and have it back in working order in less than half an hour, without even driving back to the barn.
