Re: IH 400 Cylinder wear specs
Posted by rustyfarmall on August 12, 2014 at 08:07:04 from (208.126.186.41):
In Reply to: IH 400 Cylinder wear specs posted by husker44a on August 12, 2014 at 07:52:31:
If there is a ridge at the top of the cylinder, it is time to replace the sleeves. If there is no ridge, most likely that cylinder is not worn enough to need attention.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
