Re: Farmall only runs with choke closed
Posted by rustyfarmall on August 12, 2014 at 08:14:26 from (208.126.186.41):
In Reply to: Farmall only runs with choke closed posted by R Weld on August 11, 2014 at 16:23:36:
There is a fine mesh screen in the fuel inlet fitting on the carb. That screen is probably full of crud. The fitting is made of brass, and takes a 5/8" wrench. Remove it, clean the screen with aerosol carb cleaner and compressed air. If the screen is missing, then someone before you took it out because it was plugged up. If that has happened, you will need to take the carb apart and clean it thoroughly.
